poor performance
JonChristman
poor performance
Post by JonChristman »
I have only had my F26 for about 6 weeks and I finally got it out on the lake for an extended run and I have some concerns over the performance and wanted to get some input from the experts here to see what their options are.
This 1980 has the original Chrysler 318. As I throttled up I maxed out at about 3000 RPM and speed was about 16kts. I pulled back on the throttle to a comfortable 2400 RPM and was cruising about 12kts. At either setting it didn't seem to have enough speed to plane out properly. The trim don't seem to be working properly as I could not detect anything either up or down with them.
I want to get your thoughts on this. Should I be expecting more from this ancient power plant? What can I do to get it help it out a bit? Should I be able to get on plane with heavy use of the trim tabs?
Jon
Jon
Former Owner of F-26 "Tir Nan Og"
and looking for another Trojan
Is the bottom clean ? what rpm are you getting at Wot ?
JonChristman
Not sure how clean the bottom is, probably not since it was put in the water
I will know for sure tomorrow as it gets pulled from the water for the winter and hauled home.
Jon
MattSC
Post by MattSC »
Hi Jon, welcome to the forum. Your 318 should be able to reach 4000 rpm at WOT.
-like Prowlerfish stated, make sure your bottom is clean
-Do you know what prop is on the boat? A Chrysler 318 with a borg warner 1:1 should have a 14 x 10 cupped propeller
-I'd also fix your tabs, are they all the way up? You should be able to get on plane without having to use your tabs too heavily
When I had a 318 in mine I'd cruise at 17kts, 3100 rpm and max out at 25kts 4000 rpm. I could obtain these speeds at those rpm's and was just shy of 2000 hrs before I did my repower. The 318 is a great engine, we should be able to help you figure it out.
Matt
my money is on a dirty bottom and or barnacles on the props.
It doesn't take too much there to greatly affect performance.
IF the bottom is clean, make sure you're getting full advance out of the distributor...common issue with these.
k9th
Post by k9th »
I doubt he has barnacles in Lake Erie or another smaller inland lake which is where I am assuming he is since he is in Norwalk, Ohio.
Sounds like maybe a prop issue or timing advance. I would also check the compression since he states it is the original engine which makes it 30 years old.
If I am reading his post correctly, he has owned it for six weeks and just now got it out on the lake for an extended run.
JonChristman
Yes, the boat is on Lake Erie so no barnacles. But the bottom was covered, qute heavily with a lot of green slimy nastiness which I am sure was dragging down the boat.
After the cleaning it is a pretty blue again. but it will need a new paint job pretty for sure.
I will definitly look into the distributor too over the winter.
Jon
rbcool
Post by rbcool »
Two of my slip neighbors have similar boats, both with the 318s. Both had the exact same problem until they each replaced the props. Now they're both running great.
Also.... you can always check your tabs by putting your boat pole on top of them and having someone push the buttons. You'll see the pole go up and down.
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Upper Bay, Chesapeake Bay
JonChristman
The prop is the right size, and shape. It is slightly pitted and rough, but not extreme. Should I replace the prop?
I did some troubleshooting on the tabs this afternoon and it appears they are getting no power. The hot wire fed from the 12 VDC Refridge main box (Why he connected it there is a mystery) I moved the wire and tied it to an open fuse and bingo, got working tabs now.
The next step now will be troubleshooting the refridge main to determine why that doggone thing is not working... :-)
Jon
rbcool
Post by rbcool »
Welcome to boating..... we would go crazy without a list! :D
Ronald Reagan
1987 F36 Tri-Cabin
Twin 270 Crusaders
"Special K"
Already out for the winter? Ouch. Boating seas=on is just resuming here (after the summer 95 deg lull).
Clean bottom makes a lot of dif ... check the timing, etc. all the usual things on a 30 year old engine.
JonChristman
End of season here is Nov 1, but I am going to be in Hawaii for the last two weeks of October so had to pull it out this week. Fortunately this past weekend was beautiful on Lake Erie, 78 sunny, and waves less than 2ft.
Jon
k9th
Post by k9th »
Mine is coming out Saturday. Like you, beautiful this past weekend on Lake Michigan - waves <1 ft. and about 80 degrees and sunny. Nice way to wrap up a season. Still get depressed though.
Peter
Post by Peter »
going to try to squeeze out 3 more weeks....
Please insert acceptable political or boating statement here...or not... I really don't give a crap....
