just got my genset fixedededed (carb rebuild), and am planning on using the crap out of it this weekend.
i've used it a few times before, but generally just to nuke something etc. this weekend, and from now on actually, i plan on running it each time i go out, per the advice of my mechanic. anyhoo, the question is this: how much petrol will a onan 6.5 use with sustained useage? (running ac, with other stuff as needed)
thanks in advance.
6.5 Onan Genset Question
Tuck
Terran
1986 Silverton 40' Aftcabin
Terran
(former 1977 F-32)
Terran
(former 1977 F-32)
uses about 3/4 to a gallon an hour depending on the load. more load a bit more gas etc. good to have some kind of load when you run it especailly if you dont use it very much
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
I am not certain if my tank is 40 or 50 gallons but I can run mine for over 14 hours straight with two Cruise Air compressors, the fridge, the occational microwave, or blender and the TV's without issue. Could of course run it longer if I didn't run both A/C units.
79' Carver 28' Mariner
