Hi
There was some comment recently concerning what to do with recovering the hatch. A couple of seasons ago, the teak veneer on my hatch was badly rippled and essentially, all worn out.
I removed the hatch itself and took it to home to my garage workshop.
I decided to strip off all of the old, ruined teak veneer and this left me with an uneven splintered mess. I sanded it with a belt sander and then applied polyfilla into all the uneven grooves and gouges. Then I sanded the polyfilla as best I could in order to obtain a smooth surface for the new surface material.
I decided to cover the area with white melamine which I eventually glued into place, very carefully. It took a bit of measuring and remeasuring, to get it to fit exactly.
Before gluing the melamine sheet onto the top side of the hatch, I completely sanded down the surounding Teak sides of the hatch and then finished them with cetol.
Only after that work was finished did I actually glue down the melamine.
Then I carefully masked the teak "cetol finished" outer edges of the hatch and then spray painted the melamine hatch top with white gloss melamine spray paint. I applied several coats.
It has stood up very well.
Hope this is of use to someone.
http://s869.photobucket.com/albums/ab252/rickdow/hatch/
Tricabin Hatch finishing
turtlem1969
