Rule bilge pumps - did Trojan use in '88?
BobCT
Post by BobCT »
I replaced my aft pump last year when I got the boat and just replaced the forward engine bilge switch and mid cabin switch.
I'm going to go ahead and replace the only other switch. I have a spare pump and switch on board now as well.
Did Trojan install Rule pumps from the factory? I don't have any records with the boat just curious if they could be original.
bobg
Post by bobg »
It appears nobody knows the answer to this one. I can check what I have when I go out tomorrow, but I have no idea if mine are original either.
I don't know if they were original...
I had a POS Sea Choice float switch in my boat only a year old and it failed. Replace it with a Rule and never looked back.
You could call Bob here and ask or John at Marine Tech, they would be able to answer your question.
In 1977 Trojan use lovett bilge pumps ( I have the paper work) they are not cheap but I believe they will out last any other pump
