Fuel tank cleaned
TADTOOMUCH
Fuel tank cleaned
Post by TADTOOMUCH »
Had my gasoline tank on starboard side cleaned. Photo shows the crap that was removed.
http://www.flickr.com/photos/tadtoomuch/4529738004/
Port tank looked brand new inside. Now my starboard tank isn't bad either. Not sure why one tank would be worse than the other.
Thanks to Torre Miller from dieselfueldoctor.com for taking on my gasoline tank. I've been fighting this crap in my tank for three years. It all runs great now.
He also owns a F-32 1973
Boat Name: A TAD TOO MUCH
MTP
Post by MTP »
just for the record you suck at the internet.........now I will go back and copy and paste you link and see what you tried to post
TIKI III
1985 F32
270 Crusaders
Wet and happy
MTP
Post by MTP »
server not found
TIKI III
1985 F32
270 Crusaders
Wet and happy
LSP
Post by LSP »
tad .....try it again
Will - LSP
1976 F32 "Donegal"
1985 10 Meter "Whakanui"
Hog Pen Creek
Middle River, Md
TADTOOMUCH
Suck at Internet
If at first you don't succeed, keep on sucking till you do succeed.....Sylvester the cat.
MTP ... YOU suck ..
Copy/paste the URL and it works fine. Or just click here.
jimbo36
Post by jimbo36 »
Tad, did you remove the tank for cleaning? jimbo36
TADTOOMUCH
He cleaned it while in place. Used a filtration system that could separate large junk first and 10 micron stuff second. Had a tube he could run down fuel float access hole and then recirculated back into fuel filler hole in deck. Took a couple hours but it's spotless now. He said the stuff is just degraded fuel. Looks like gravel and when you mash it between you fingers it turns to a fine powder.
