Problem removing the drive shaft
Rodman
One of the set screw bolts is broken. I tried to drill it today, with no luck it would not. I am thinking this is some very hard steel. Anyone have ideal how remove it.
Trojan
Danny Bailey
Rodman
Danny Bailey wrote:With the set screw broke off you'll have to split the coupling lengthwise with an angle grinder to get it off. I sent you an e-mail on the Kenyon stove. Did you get it?
let me look I have not checked in in few days, I cant see it can you just pm me here would be better. I found it . I want it even if its not working
Trojan
Danny Bailey
Rodman
No i am not replacing it. I am going to go get Carbide Bits in the am see if that will do it.prowlersfish wrote:Are you replacing the shaft ? if so cut it and then you can put coupler in a drill press or just replace it .
Trojan
reelfishin
I would soak it with a good penetrating oil and the tap on it with a steel rod the same size to loosen it up. The try drilling a hole in it and use a easy out. I have found that the skill cheap set of drill bits do pretty good. I have drilled stainless steel with them. They come in a red drill bit box and are around 15 dollars for a set. Titaniamin bits work good too. Do not let them get to hot. Speed is what kills a drill bit fast.
May I ask why your pulling the shaft ?Rodman wrote:No i am not replacing it. I am going to go get Carbide Bits in the am see if that will do it.prowlersfish wrote:Are you replacing the shaft ? if so cut it and then you can put coupler in a drill press or just replace it .
Rodman
The strut was broken from hitting coral reef. I want to make sure the drive shaft is not bent.prowlersfish wrote:May I ask why your pulling the shaft ?Rodman wrote:No i am not replacing it. I am going to go get Carbide Bits in the am see if that will do it.prowlersfish wrote:Are you replacing the shaft ? if so cut it and then you can put coupler in a drill press or just replace it .
Trojan
