Under water transom lights
I was thinking about installing some lights on the back of the transom. Does anyone have any experience with this. Which ones are good??? Do you go LED or Halogen??? Any concerns with putting another hole in the hull??? Anyone ever do it?
Go with the LED. I bought some Halogen at good price when I went to install them there was a big caution not leave them on when they are out on the water (like when on plane ) as they will over heat causing damage to the hull or worse (fire ???) now I had no need to leave them on when on plane but what if I forgot ? I waste a lot of $$$$ on something I will never use Glad I did not install them I may get some LEDs
Well ... the LED lights last forever - use less power - produce no heat - and last forever ...
Did I mention they last forever? Or at least until your great grandchildren might need to replace them because the wires rot out in 100 years.
The Halogens are better for lighting up the drunk Santa on the roof!
