oil cooler? Connections?
cuppa
Post by cuppa »
Any one know what the red bands are? I assume they are something to replace the crimp connection.. I have never seen them before.. The cooler was replaced and these are now leaking....
Any thoughts?
Check the link can't get picture to sho up..
http://briancoffeyrealtor.com/oil.bmp
It's part of the hose and connector. I just replaced mine last year...they allow the fitting to swivel. The new hoses come with the fittings.
What's the year and engine application?
cuppa
Post by cuppa »
It is a 1985 f-36 with a model 350 (454).
Can you poit me to these on the web? does it not use the crimp connection?
Does this pic look familiar?
Part numbers are here.
Ref # Part # Description Quantity
LH RH
1 179820 Bolt, 5/16 X 18 X 1 1/4" Hex HD (GR5) 2 2
2 179820 Bolt, 5/16 X 18 X 1 1/4" Hex HD (GR5) 3 3
3 103340 Washer, 5/6 Flat 1 1
4 96566 Clamp 1 1
5 97342 Bracket, Oil Filter Support 1 1
6 20156 Gasket, 1/8 Sq. Ring 1 1
7 97667 Adapter, Remote Oil Filter 1 1
8 22167 Hose Assembly, #10 X 42 1/2" Block to Cooler 1 1
9 22226 Washer, 5/16 Copper Flat 2 2
10 179828 Bolt, 5/16 x 18 x 2 1/2" Hex HD (GR5) 2 2
11 22169 Hose Assembly, #10 x 12" Filter to Block 1 1
12 102634 Nut, 5/16 - 18 Hex 2 2
13 103320 Washer, 5/16 Medium Lock 2 2
14 22168 Hose Assembly, #10 x 53 1/2" Cooler to Filter 1 1
15 30550 Elbow, 1/2 Pipe x 1/2 Tube, Inverted Flair, 90 ° 1 1
16 30549 Elbow, 1/2 Pipe x 45° Inverted Flair 1 1
17 719571 Adapter, Remote Oil Filter 1 1
18 97292 Nipple, Filter Adapter 1 1
19 9002514 Oil Filter, PF2 1 1
cuppa
Post by cuppa »
it does...
So the red band is some time of faster? is it plastic?
Does it fit down in to the rubber hose?
Pay no attention to the red band. Order new hoses and the elbow fittings as needed and be done.
cuppa
Post by cuppa »
So are they new hoses if they have red bands on them or is this some type of aftermarket fix?
Did they replace the cooler and not use new hoses?
I believe they are original. The parts listed previously are from Crusader.
I know yellow bands are used to ID parker pushloc and weatherhead barb-tite fittins . these are both clampless fittings.
http://www.parker.com/literature/Hose%2 ... 1%20B1.pdf
http://www.imperialinc.com/grp161.shtml
cuppa
Size
Post by cuppa »
Does any one happen to know the Diameter of this hose?
