replacing starboard alternator
it is a one wire
does anyone have a part number?
I found mando 39200
prestolite 39064
Motorola MR
also current belt size is 47 5/8" which seems a bit long
thx
rr
89 mid cabin alternator and belt size
10 meter mid cabin
Re: 89 mid cabin alternator and belt size
Any photo of your Alt? Beacon Marine has some
https://www.trojanboats.net/zencart/ind ... th=102_110
Assuming your engine serial number is greater than 88710, the alternator numbers you quoted are correct and my recommended replacement would be an Arco 60104, $191.59 through Amazon.
Regarding the belt size, again assuming serial number greater than 88710, the correct belt part number is Crusader #98210
"Speakeasy"
Model 340
Twin 454 (350hp) Crusaders
1.5:1 Gearboxes
Jacksonville, FL
Model 340
1.5:1 Gearboxes
Jacksonville, FL
thanks guys
serial number is 76868
I bought a DB Electric from Amazon
Looks like it will work, I'll Let you know if it doesn't.
As for the belt, that crusader number gives me a spec of 49 1/8" which is too long.
I will use the old belt as a guide.
rr
rr
10 meter mid cabin
