F 44MY. Diesel.
Pcravens
F 44MY. Diesel.
Post by Pcravens »
A couple of questions. How much fuel do the rear tanks under the bed hold each. And also the 2 smaller tanks on each side of the engine compartment. And can I some how pump the fuel in the small tanks to the rear tanks. I think I have a leak in one of the small tanks. Thanks
Re: F 44MY. Diesel.
Not sure how I missed this I will look it up
Re: F 44MY. Diesel.
Can you tell me what exact F44 MY you have, as there are 2 different ones plus a sedan? also the year. If you are not sure a photo or the hull ID number will work.
Also, Tank info will be in your owner's manual. If you don't have one, Beacon has them.
Re: F 44MY. Diesel.
You also can get the fuel valve diagram from beacon, its also in the manual.
