Mercruiser 228 MIE replacement...
F26 1978
Post by F26 1978 »
Hy,
Thank's a lot for the add !!!
I'm a New owner of an 1978 F26 Express Trojan boat.
Engine is close to 2000hr never rebuilt or oversize. It's a Mercruiser 228 MIE (5 L)
I would like to know if i can replace this engine with a bigger one like a 5.7 ? Or a 350 mpi ? I think about the room for à bigger one...
Thank's if you can help...
David,
Quebec, Canada.
Moderator
2026 Support
2026 Support
Re: Mercruiser 228 MIE replacement...
Post by Moderator »
I am moving this to the boat section more will see it there.
Moderator
Forum Moderator
TrojanBoats.Net
Trojan Boater
The 305 and 350 are the same block ( different bore )
oldboat1
Post by oldboat1 »
I have a 1980 version of your 305 in my F26 — about the same number of hours. I’ve been a little unhappy with top end speed, and have thought maybe the engine was just tired.
At the end of last year’s NY boating season, I went back to tinkering with carb adjustments on the 4bbl Rochester. I thought the spring tension on the secondary doors was set right, but found that the secondaries were apparently running too rich. When I hit on a better setting, the boat performance was much improved. I did not get in much running, unfortunately, before the hook on the end of the spring broke.
The proper tension screw adjustment on mine appears to be 3/4 turn closed from lightly seated. So if you have a similar carb, and similar performance complaints, you may need to adjust the secondary door tension.
1980 F26, Mercruiser 305
