1081 F32 steering
fpawn
1081 F32 steering
Post by fpawn »
Lost steering on bridge due to a leak in teleflex helm leaking fluid. Can these be repaired?
Re: 1081 F32 steering
1081? I asume you mean 1981 :) . Are you sure it's a Teleflex helm? They came with Syten helm pump the later ones used Hynautic. The syten can not be rebuilt/resealed. It would need to be replaced with a sea star helm pump ( takes some work to do). If you have the Hynautic it can be resealed, its a little tricky as there is a lot of parts. Do you have a photo of the helm? Yours may have been replaced.
Man times the the Syten, teleflex and sea star pumps crack. Not an issue with Hynatic.
fpawn
Post by fpawn »
Yes meant 1981 F32. My steering is Syten system with a leaking top side helm. Bottom station works
You will have to replace the leaking helm with a seastar. Bob at Beacon marine can tell you what you need,
