I'm in need of pics of the rudder support beams. I have my old pics for reference. I'm replacing the old ones but I'm trying to figure out why there were blocks bolted to the side of the stringers for them to sit on?
Why not just go across the stringers?
Advise and thoughts would be greatly appreciated !
F32 Rudder support beam replacement
Re: F32 Rudder support beam replacement
- IMG_20210407_122517197.jpg (199.66 KiB) Viewed 5447 times
- Beacon Bob
You need to put it back the same way so safety collars roll pin will fit into same hole. Rudder port is the lower bearing. The top of the rudder should be 1/8 “ or less before the end of the rudder port.
- 7706FF5B-FE83-4DC2-8C9C-EB3A5138BCEF.jpeg (93.57 KiB) Viewed 5423 times
Looks like I will be purchasing the wire pins and collars.
Thanks Bob
Thanks Bob
Looks like your doing some nice work .
Thanks for the compliment. Stringers and bulkheads are replaced. Now working on rudder system. And also will be having the fuel tanks reconditioned. As for the original water tank it also is getting reconditioned.
