Back light for guages
HiredKiller
I recently purchased a 1986 Trojan 11 Meter and am in the process of learning systems. Do the back lights for the gauges come on with the Nav lights switch?
Re: Back light for guages
I don't believe so , but I don't own a 11 meter so I am not a 100% sure . Do you have a owners manual ?
My 10.8 meter has a switch for the panel lights
Same here on my 1983 10 Meter
separate switch
has a resistor in the dash to dim the instrument lights
My '88 12 meter has a separate switch.
I am actually in the process of converting them all to LED, and adding a dimmer switch.
HiredKiller
Nothing seems to come on when I turn on the panel lights switch. There doesn't seem to be a Fuse/ Switch for panel lights at the main panel? I could not find any information on this in my owners manual.
My big problem was grounding issues, as the "backplane" of the gauge cluster acts and the ground for all the lights. The PO had done a bunch of weird stuff, so it was easier to kind of start from scratch with the original wiring diagram from Beacon.HiredKiller wrote: ↑Tue May 19, 2020 10:10 am Nothing seems to come on when I turn on the panel lights switch. There doesn't seem to be a Fuse/ Switch for panel lights at the main panel? I could not find any information on this in my owners manual.
hammerhead
i have a 79 f30 and want to change out the back lights because most dont work. the are the original gauges and i cant seem to find leds for it. any help would be greatly appreciated
Check with Beacon marine
