Swim Platform Support Arms
Briank117
Post by Briank117 »
Hey gang,
Looking for alternatives to the (wooden) support arms I'm currently missing for the swim platform. All hardware is still there attached. Is stainless my best option? Not hauling until spring, but I'm trying to start the "to-do" list and gather misc supplies.
Brian
DAVIDLOFLAND
Re: Swim Platform Support Arms
Post by DAVIDLOFLAND »
I installed my swim platform about 20+ years ago. For support arms, I simply cut 7/8" or 1" (can't remember which) stainless tubing to desired length for each strut plus about 2" at each end. I then flattened each end in a vice, bent the flattened end about 45 degrees and drilled a hole, then ground the sharp corners.
The upper supports are 1/4" aluminum plate I had a machine shop 'break' to the correct angle, then I just chopped it into 4" sections.
It's held up in salt water for over 20 years.
Yanmar 6BY3-260's
Paul - SW Ontario
Post by Paul - SW Ontario »
Did the same thing as David for the aft supports. (They are actually the old Trojan railings cut down - waste not want not!)
Had Aluminum triangular supports made by a local welder for the transom supports.
Been going strong for 11 years now...no problems.
1973 Trojan F25.5 - SW, ON.
2012 Triple Axle trailer
1978 C&C Mega 30' Sailboat
2014 Triple Axle trailer
2016 Highfield CL290 BL RIB
2017 20hp Suzuki 4 stroke
Briank117
Post by Briank117 »
Fantastic job guys! Great ideas. Thank you very much!
When I swapped out my swim platform, Beacon Marine had the necessary additional brackets :)
