I have a 44' FBMY and I'm having trouble with one of the air conditioners. The system will run without any problem in the run position but when I switch to start the fan will sound labored and the breaker will trip after 10-15 seconds. Any suggestions on where to begin? I have looked at all wiring and nothing stands out as obvious. No burnt or charred(overheated) terminals.
Thanks everyone for any suggestions...... Jim
Crusiar air conditioning
Re: Crusiar air conditioning
Could be one of the capacitors or the compressor it self . Lack of water flow would do the same but it would normally take a little longer to trip the breaker
Thanks, I thought of the compressor but not the capacitors. I don't think water flow is the issue as I am getting the same steady stream overboard as always...
Thanks again......Jim
