Municipal water inlet
boyman52
Post by boyman52 »
F40 owner. Is there a way to know whether or not the check valve is open or closed for the municipal water inlet? I've found the check valve, but don't see any way to check if it's open or closed. Help???
Re: Municipal water inlet
Are you sure its not a pressure regulator ? What problem are you having ?
