I have a 1985, 10 meter International. Recently my ac unit quit and when I removed the digisette control switch it was clear that a couple of wires had overheated and melted. It may be hard to rewire and I have tried to search for a switch but have not found one. Is there a suitable replacement available?
Don
digisette ac switch
digisette ac switch
Thanks for the info
Re: digisette ac switch
I have not heard of Digisette but you may want th check with Bob at Beacon marine
- Beacon Bob
Digisette is the Lunaire controller. Part is NA unless you can find a used one.
Marine Air which is now Dometic made a thermostate kit that would make the Lunaire work.
You may want to look at replacing the unit.
Mermaid Air Conditioning Units have a 5 year warranty.
Also check E Bay for a used Digisette controller.
We should have the electrical drawings for the Digisette
Beacon Marine
609 713 4602
Beacon Marine
609 713 4602
