FYI
I am in the process of replacing the cutlass bearing on my 1972 F26 Trojan Hardtop Express. I had to remove the strut and then use a hack saw and a set of sockets to pound out the old bearing. The required bearing was for a 1" shaft and had an outside diameter of 1 1/4" and was 4" long.
Now when I need to replace it again in a number of years I can search this forum to find out what size I need.
Thanks trojganboats.net
Ken
1972 Trojan F26 Express
Chrysler 318 Reverse Rotation
Paragon PV31R V-Drive
Norfolk, VA
Cutlass bearing for a 1972 F26 Trojan Express
- vabeach1234
You will also find you cutlass bearing has an name ( should be on the outside and the box . just rember the name . as the name only matchs with one size bearing . I think yours is a" back"
http://www.deepblueyachtsupply.com/series.aspx?id=2
