No oil pressure!
No oil pressure!
My 1977 Tri-Cabin has twin 440 Chyslers in it. One of the engines has "0" oil pressure. My mechanic put a new oil pump on it and it still showed"0". He then, using a drill, manually spun the gears and only a little drip of oil came out. He said the next thing to try would be to reverse-pressurize the system. Has anyone any other ideas?
did the sump tube come loose? If the pump is good, theres not much else .....
- LOOKOUT AGAIN
- 1986 F-36
- Lake Michigan Fish Slayer.
Sump pump.
That's what my father thought....The pick up tube came off. I guess I will have to pull the motor?
