Potable water plumbing layout 1990 F32
AndyF32
Post by AndyF32 »
I was hoping someone may have a drawing of the layout of the plumbing on a 1990 F32. The lines under the cockpit have become very brittle. I have done a temporary repair to get me thru the end of the season but thinking I should probably replace all of the lines.
Reel Easy
Re: Potable water plumbing layout 1990 F32
Post by Reel Easy »
What model F-32? Express or sedan? There are different layouts. All of your domestic water can easily be replaced with PEX or UPONOR tubing from Home Depot or Minards or plumbing supply house.
Dustin
1999 360 Express twin 7.4
Catawba Island, Ohio
Nothing like a water leak on a boat to make life interesting.
Reel Easy
Post by Reel Easy »
Flex seal will fix that. Lol. I watched them cut a boat in half and seal it.
Dustin
AndyF32
Post by AndyF32 »
Mine is a sedan. The water lines under the cockpit have become very brittle and the outside is disintegrating.
I believe my Trojan owner's manual has a diagram of the plumbing layout... but mine is a '79, and have the info at the boat (not home), so can't help right now... and don't know if it changed over the next 11 years! If you contact Beacon you can get a manual from them for your specific boat.
