Gauges are pegged
Gauges are pegged
I have a Trojan 28 with twin 318s. The port side gauges Fuel & temperature (top & bottom) work fine and register as I think they should. But the Starboard side gauges top and bottom are pegged to the right. Is this a grounding problem or a gauge problem? This is just the next item on my list to check and verify. Thanks for comments, going up this weekend and needed a place to look.
- The Dog House
Re: Gauges are pegged
If your gauges are pegged to the right most likely the signal wires are shorting to ground. Faria has a very helpful troubleshooting guide at https://fariabeede.com/site_manuals/IS0100q.pdf .
Thanks, Dog House
I was thinking a ground issue myself
