Trojan F 36 Trim Tabs
fdean396
Post by fdean396 »
What type of fluid should I use for my F 36 trim tabs?
Plan B
1972 - F36
Re: Trojan F 36 Trim Tabs
ATF ( trans fld ) I normally use Dexron but the system is not that picky
Boat leveler makes a Biodegradable oil for their system , But ATF is much easier to find .
fdean396
Post by fdean396 »
Thank you for the info!
Plan B
1972 - F36
oil&water
Post by oil&water »
Well this post was timely. Thanks for the info.
Currently Trojan-less :?
