May 2017 Upper Bay Rendezvuex
Doc Holiday
Post by Doc Holiday »
Hello Everyone!
It's been a busy autumn yanking out the stbd 6-71 for its rebuild but she should be ready to go by mid-spring.
6-71 Engine Removal .png (107.84 KiB) Viewed 5255 times
671 Eng Removal (22).JPG (201.78 KiB) Viewed 5255 times
671 Eng Removal (24).JPG (201.27 KiB) Viewed 5255 times
I'm probably doing a shake-down cruise to Higgins in St. Michaels the beginning of May and going to Henderson's Wharf in Fells Point towards the end of May. John Leed will be in tow both trips as the tech advisor. I'll update this post as the dates firm but thought I'd send out some tentative plans for the start of the 2017 season.
Re: May 2017 Upper Bay Rendezvuex
I met John Leed at Higgins in 2009 . He came down for the rendezvous . Good luck with the project
Doc Holiday
Thanks prowlersfish! John said that the Trojan design team took great pride in making sure engine swaps could be accommodated without cutting fiberglass.
671 Eng Removal (2)-1.jpg (187.06 KiB) Viewed 5243 times
I jokingly asked him if that meant sometimes lifting the engine vertically... A serious "Yes" was the reply.
6-71 Removal 4.jpg (134.41 KiB) Viewed 5243 times
Think I'll wait to bolt on the turbo until after the block is back in place!
I had to take my door off but the Cummins came right out of F36 , I could removed the stop and opened more but the screws would not budge.
You should try and get a 671 out of a Viking 45 . Not fun
I forgot to ask what Yard are you at ?
Doc Holiday
Bay Boat Works on the North East River. Great people there.
It looked familiar , but I can't recall going there . But I believe I when to Jackson a few years back (by land) so its possible .
If you are suggesting a get together in St. Michaels or Baltimore, we are interested. The only caveat would be our older daughter is graduating the weekend of the 13th, so that would be out for us.
