Engine synchronizer
AndyF32
Engine synchronizer
Post by AndyF32 »
Anyone know where I can find one of these? I am looking for a surface mount rather than a panel mount.
Thanks
Re: Engine synchronizer
Could be wrong but I don't know that they even make those anymore. Seems everyone is making the gage type. You can go the analog gage/dial type and mount it in a single gage pod on top of the helm.
AndyF32
Post by AndyF32 »
They do not make them anymore,was hoping to find a used one. Have not found a single gauge pod I liked.
I have an old style synchronizer mounts via a gimbal type arrangement. I never used. It is a hooded type that has some type of lens in the front. I think you just hook it to each tach pulse wire. If you interested give me a shout. I assume it works but not sure as I have never seen it working, have seen it described on this forum.
903-896-1610
bjanakos
Post by bjanakos »
I may be willing to trade, or give you mine. I find them rather distracting and I am honestly better at doing it by ear.
bjanakos
Post by bjanakos »
I was actually thinking of pulling my tachs and replacing one of them with a dual-tach/flow meter. I was trying to figure out what to put into the other hole.... Maybe a 3" synch or another combo unit.
comodave
Post by comodave »
I replaced my tachs with a Twin Scan flow meter. One gauge has both tachs in it and the other gauge has the 2 fuel flow indicators in it. Both tach holes are therefore filled. Looks good and the tach are in the same gauge so it is easy to see if they are close, besides the Twin Scan has a sync function also. And the price was very good, they were given to me for free.
Trojan has been sold
Au Gres, Michigan
AndyF32
Post by AndyF32 »
Larry,
Thanks for the offer. On those i don't think you can tell which is running slow so it takes more fiddling with the throttles. The newer style shows approx how much slower one is running.
BigD,
Thanks for that link, the 2" pvc pipe option to make a gauge pod may be the way to go if I cant find a older unit.
Svend
Post by Svend »
what are flow meters... and how can they help with dual engines?
thanks!
Svend
Raymarine EV 100 Auto Pilot
BobCT
Post by BobCT »
They precisely measure and display how much fuel you are burning real time. Check out Floscan as one of the more popular companies. Once installed, RPM and trim tab adjustments can be immediately viewed on each engine.
Svend
Post by Svend »
hi all...
how do you remove the engine synchronizer?
thanks!
Svend
