Trifly aft "stateroom" cushion
Misty
Post by Misty »
Hi guys,
Trying and flying here. Figuring out the aft filler cushion config is a challenge though. The PO supplied me with a cushion, but no "board"(what she called it) to span the walkway between the twins in the aft stateroom. Can anyone explain if this is a normal or custom config, how it works, and possible improvements?(PO described it as least comfy bed ever)
Trojan F36 Tri Cabin, Thousand Islands, NY.jpg (42.59 KiB) Viewed 7322 times
Barrie
Re: Trifly aft "stateroom" cushion
Post by Barrie »
I would like to help here, but mine was also missing.
I am curios how this would be accomplished, I don't remember there being a ledge or any form of bracket for it to sit on.
Barrie
Aylmer Ontario, Canada
36' Tri-Fly "The Obvious"
Misty
Post by Misty »
Yeah, it just doesn't add up. But before we make something new its nice to know what the original plan was!
Wait for Aaron... as our resident TriCab guru he will most likely have the answer.
I am confused, is the "trifly" the same as the "tri-cabin'? My tri cab has a full bed in the owners suite.
larryeddington wrote:I am confused, is the "trifly" the same as the "tri-cabin'? My tri cab has a full bed in the owners suite.
Tri Cabin and Tri-Fly are different layouts and superstructure designs, built on the same hull. The tricabin essentially has a raised mid cabin (salon area), with lowered forward and aft sleeping quarters (as you know); with only a single steering station - up top. The Tri-Fly is a 'flybridge version' of that, where the salon design incorporates a second helm station. And then the upper deck has a second steering station.
Here is a tricabin : http://www.google.com/imgres?imgurl=htt ... kgodNIEEmA
Here is a tri-fly : http://www.google.com/imgres?imgurl=htt ... kgodNIEEmA
The layout Misty posted looks more like a normal tricabin layout than a trifly. The layout for the tricabin also evolved over the years (credit : PowerBoat Guide). By the way : built from 1970 - 1987.
thanks, got it clear now. :)
Misty
Post by Misty »
Mine is the layout I posted. Engines under each aft bunk w V drives and NOT under the salon floor. There are a few online that customize this to some sort of super king size, but Id like a thoroughfare. May have to pull the trim and put my designers hat on. Stand back if that happens... My vision: A "Tricushion?"
Barrie
Post by Barrie »
Hey Misty, my tri fly has the same layout as the picture you posted, with the exception mine has a steering station at the "L" shaped sofa in the salon
Barrie
Surprised Aaron hasn't landed yet.
If it helps in the meantime, based on my F32... for V-berth there is a 1/2 - 3/4" 'shelf' around the edge of the vberth opening that the filler panel sits on.
You can see a little bit here (apparently this is the URL for the ad, not just the pic I wanted...) https://www.google.com/url?sa=i&rct=j&q ... 0519080773) .
In the dinette, there are legs that the table top sits on to convert to a berth, as shown here (again the URL for the ad, not just he pic I wanted.... https://www.google.com/url?sa=i&rct=j&q ... 0627151383).
Don't know which of the two are most likely to align with your aft cabin setup, but thinking the first is more likely.
aaronbocknek
Post by aaronbocknek »
HERE I AM.............. sorry fellas. it's been a while. i'll explain later. the aft engined tri cabins NEVER had a filler between bunks. the gap is just too big. of course, you could modify something, but it would need to be supported in the center of the filler. then again, we are masters of customizing, so, the the options and ideas are limitless..............
aaronbocknek@gmail.com
Post by rickalan35 »
Agree with Aaron but wasn't confident enough to say as much. I sold my Tricabin two months ago and bought another Trojan but my former '74 Tricabin (had it for 16 yrs) was also a V-drive arrangement and therefore like Aaron has indicated, there was no filler pad.
But, I widened the port side berth by ten inches by having a carpenter build it out into the space between the two berths.
Secondly, I removed the hollow, partition that was stock on the outside wall of the berth (thus losing the shelf) - this increased the berth size by another ten inches.
(I installed a new teak section right next to the fibreglass interior freeboard)
All in all, after getting a custom mattress made (and paying too much for it) we had ourselves a pretty big, comfortable berth.
Wondering if you could borrow off the ideas of how the dinette is converted to a double berth on most of the older Trojans, or how the v-berth fills in? Aaron says the gap between the berths is just too big, but how wide is it?
Captain, I believe it could be done. I think that a section of 3/4 in plywood with a cushion affixed, could be made to fit in that space if resting on side supports . This section could then be popped out and stored on top of one of the bunks during the daytime hours, thus allowing for access as a passageway and also for checking the engines.
The issue would be getting into bed or getting out, as there would be no side access. It would be similar to getting out of bed at home by climbing over top of your own pillows. Sort of unnatural, but doable I guess.
Misty
Post by Misty »
Thanks guys!(especially Aaron!) What I have is just the cushion and not the board as forensics evidence. When you enlarged the one berth what happened to the walkway? Or do you mean you got the 10" from eliminating the shelf? Ill have to think about that! :shock:
