To Switch or Not to Switch - That is the Question
- DAVIDLOFLAND
Hey guys,
I'm at the engine/battery electrical wiring stage of the re-power. Existing wiring from 1977 connects battery to starter directly (not switched). Polling other boaters reveals about 60/40 in favor of this 'not switched' configuration. One marine electrical guy says switched is 'code'.
What are you guys' thoughts?
Thanks, Dave
Thanks, Dave
Yanmar 6BY3-260's
Yanmar 6BY3-260's
- The Dog House
Re: To Switch or Not to Switch - That is the Question
All of my boats have always been switched. The only things connected directly to the battery are the bilge pumps.
And the charger.The Dog House wrote:All of my boats have always been switched. The only things connected directly to the battery are the bilge pumps.
My charger has inline fuses before the battery.
- The Dog House
My bilge pumps have in-line fuses.
I just added switches. three to be exact. when they are all set to position 1 they each draw from their individual banks. if a battery goes bad i can isolate it and run off the other two. im also using blue seas terminal fuse blocks that mount directly to the batterys. complies with the ABYC 7" rule.
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
- Bubbabuda
Switched is the "safe" way to go.
I would go with switches
- Away On Busine$$
I'm non electrical came someone explain the difference. I don't do glass either!
And the constant voltage wire from the am/fm.
