1989 or 1990 Trojan 10.8 meter??
guntruck
Post by guntruck »
I just purchased this 10.8 meter sportfish and the title states 89 and the owner swears its a 90 and the Trojan/Bertram plaque on the hull says 1990. Can someone shed some light maybe ?
Trojan plate.jpg (33.82 KiB) Viewed 4236 times
comodave
Re: 1989 or 1990 Trojan 10.8 meter??
Post by comodave »
Look at the HIN molded into the transom
Trojan has been sold
Au Gres, Michigan
guntruck
Post by guntruck »
Im guessing 89?
Give Bob a call.
If you need help with a TRJ number or Hull number Please call or or E mail us at Bob@Trojanboats.net
http://www.trojanboatsforum.net/wforum/viewt ... f=1&t=2941
Could be built in 89 but a 90 model , If your CG documented It will show year built not model year
comodave
Post by comodave »
I put your HIN into hindecoder.com and it shows that the serial number is JL004 that was assigned by Trojan. It has a certification date of 1989. It is model year 1989 with an August build month. It may have been originally sold and delivered in 1990. But you need to go by the HIN which is what the state and CG will use when you register or document the boat.
Au Gres, Michigan
guntruck
Post by guntruck »
Great everyone thanks for the clarity. Now time to get to work on her once i get her home =).
