Teak Work
gitchisum
Teak Work
Post by gitchisum »
took advantage of a nice fall day and started some of my winter projects. The PO had neglected the exterior teak and I actually had moss growing on the bow pulpit!
Teak 1.JPG (49.07 KiB) Viewed 3219 times
Teak 2.JPG (49.82 KiB) Viewed 3219 times
Hit the pieces with a pressure washer and they cleaned up nicely. Now on to some sanding, and Cetol finish.
Teak 3.JPG (42.11 KiB) Viewed 3219 times
I am thinking about using some type of epoxy filler where the strips on the pulpit have slight gaps in them. anyone have suggestions on what to use?
88 321 Sedan 270 crusaders
2001 Seadoo Challenger 2000
97 Lowe Roughneck 17TC
todd brinkerhoff
Re: Teak Work
Post by todd brinkerhoff »
I think epoxy will work well. Take some clear unthickened epoxy in a syringe and run it along the cracks. Then find some big clamps and clamp the entire pulpit to close the gaps. Let it dry for 24 hours. I would then sand down any high points and put 2 to 3 coats of clear epoxy over the entire surface. Let it dry and sand it. It will make a great surface for your varnish. Just make sure the varnish you use is compatible with the epoxy.
I
Away On Busine$$
Re: Teak Work
Post by Away On Busine$$ »
That's what I would call neglect on the swim platform. I had mine planned down both sides 1/64 at a time till we got to new wood. Then refinished with 4 coats of natural CETOL. Built a new bow pulpit over the winter in the same style as the swim platform and used West System 105 epoxy and stainless screws to join everything. Again 4 coats of CETOL. Now all looks brand new and you cannot tell any difference front to back. Will re-coat yearly.
gitchisum
Re: Teak Work
Post by gitchisum »
finishing up the work started over winter. I went with a darker Cetol on the finish and really like it. Same stuff I had used on my F-26.
Rebuilding all the hatches, right down to new neoprene gaskets and barrel nuts. I was able to salvage all the existing hatch hardware. Used Brasso to clean it up and it worked wonders.
Couple of pics attached
hatch snip.JPG (61.92 KiB) Viewed 3020 times
ladder snip.JPG (170.27 KiB) Viewed 3020 times
