6.5 onan
A motor running without t-stats is not efficient among other things. Having said that, I've seen Onans running for years without them. People usually don't replace them due to expense or a misdiagnosed condition. Personally, I wouldn't run without them. Why are they being removed, what are the symptoms?
not to hijack this post,
but i ran across this as an option to the expensive onan oem thermostat part #309-0130 for the 6.5 mccck
i found 2 references on the internet stating the yanmar part#105582-49200 themostat is interchangeable with the onan. i found costs $24.00 each instead of $50 or so for the onan. has anybody substitued this or similiar in the mcck series
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
- Diverted Income
Re: 6.5 onan
Would be nice if someone could confirm the Yanmar p.n. I may need to track one down and compare if not. Onan is stupid high.
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
Re: 6.5 onan
here is a picture of the yanmar one, compare;
http://www.swdieselinc.com/Yanmar_Therm ... -49200.htm
Re: 6.5 onan
Like Larry stated...take a look and decide for yourself. They look close enough to me, to work.
But there is also another Onan thermostat, a 140-145 degree which is part number 309-0130.
Yanmar Thermostat;
Sierra Thermostat; You can get at Worst Marine under number, 13480579 and Sierra number, 23-3606
Yanmar Thermostat;
- Diverted Income
Re: 6.5 onan
Yup - I need the 140* stat as mine is keel cooled
Re: 6.5 onan
I went ahead and sprang for the Onan ones for mine, not installed yet but have them as backup also points and plugs. Right now my Genny just hums so will leave alone.
Re: 6.5 onan
keel cooled ? Are you sure ?Diverted Income wrote:Yup - I need the 140* stat as mine is keel cooled
- Diverted Income
Re: 6.5 onan
Parts manual shows it should have a 140* stat if it is (keel cooled) raw water cooled. 180* if fresh water cooled, two different p.n. 309-0130 vs 309-0289. Onan MCE. Am I missing something? (probably am)
Re: 6.5 onan
You maybe raw water cooled (uses lake/bay water ) or fresh water cooled ( antifreeze w/ heat exchanger)
But I highly doubt You are keel cooled . A keel cooler uses coolant flowing through tubes or a exchanger that is mounted under the hull in the water . As a general rule they are not used on Planning hulls .Its a safe bet that Trojan never used them on a F32 .
- spiral-tube-keel-cooler-183.jpg (19.44 KiB) Viewed 8412 times
- keel cooler.jpg (7.18 KiB) Viewed 8412 times
Re: 6.5 onan
Two completely different things!Diverted Income wrote:....(keel cooled) raw water cooled......
- Diverted Income
Re: 6.5 onan
Guess I figured (wrong) 140* so it would not precipitate the river crud into the water jacket if cooler than the 180* I am wrong again. Thanks for the explanation. Still on the search for the stats though!
Re: 6.5 onan
I added keel cooler pic to my post above
- Diverted Income
Re: 6.5 onan
So what would you guys recommend 140* or 180*??
Thanks!
Thanks!
