F-32 Table
- Diverted Income
F-32 Table
I'll admit I haven't studied the mounting of the dinette table miuch but, how does it come off to convert to a berth? Does it slide forward or un clip somehow? Thanks!
1982 Trojan F-32 w/Merc 230's
1975 Baja V-1800J w/ 502 Ford
http://missriverrat.com
Re: F-32 Table
Lift it up
- Diverted Income
Re: F-32 Table
Thanks. Will look at it next time on board. It is stranded mid-trip due to high water. ( again )! Darn weather.
Re: F-32 Table
Nope. It goes down.prowlersfish wrote:Lift it up
The 'hinge and latch' system for the table works like this : Fold the leg up out of the way, then lower the edge of the table several inches (until it's almost hitting your seat cushions). It will swing down as if it is on a hinge. Lets pretend it is now leaning down on a 20 degree angle. Then lift the back edge of the table - or the whole table - up keeping it on that same 20deg angle.
Here is a quickly scrambled together diagram of what the hinge / latch system looks like, what happens when you drop the table down, and then lift the back edge out of the hinge.
- Dinette Table Latching v2.jpg (36.25 KiB) Viewed 10694 times
- aaronbocknek
Re: F-32 Table
i love your instructional drawings!! very helpful. i'm more visual when it comes to learning, and they help a great deal.
thank you.
thank you.
Re: F-32 Table
I guess I should have been more exact . But you do lift the end by the wall , I just fold the leg in and lift the other end very slight tilt needed on mine . Mine could be worn .
Re: F-32 Table
Mine is down
Re: F-32 Table
Great diagram! What tool did you use to make it?
- Commissionpoint
Re: F-32 Table
+1. Cuz thats how its done.captainmaniac wrote:
Nope. It goes down.
Re: F-32 Table
Hate to admit it, but I am an MS Office / Powerpoint weenie, and then just used an image capture tool to grab the drawing and convert to jpg. Drew the engineering drawings for my wheel hub adapter the same way a couple of years back.Nancy wrote:Great diagram! What tool did you use to make it?
Re: F-32 Table
That's funny! My sister used Powerpoint to design her summer cottage, right down to the exterior colors!captainmaniac wrote:Hate to admit it, but I am an MS Office / Powerpoint weenie
Re: F-32 Table
For THAT I would defer to my wife (the Designer), and her CAD package that does awesome 3-D renderings.Nancy wrote:That's funny! My sister used Powerpoint to design her summer cottage, right down to the exterior colors!captainmaniac wrote:Hate to admit it, but I am an MS Office / Powerpoint weenie
Re: F-32 Table
Old Post, but does anyone have info how the table in the VEE Berth works for a 1973 F31? Unfortunately the leg is missing and trying to figure out what to fabricate.
Thanks,
Thanks,
"You're gonna need a bigger boat!"
1973 Trojan F31 Flybridge W/ Twin Chrysler LM 318s
Re: F-32 Table
Table in the V-berth ? Photo please .
- AwayOnBusine$$
Re: F-32 Table
I used 2 pieces of 1 1/2 inch wide 3 foot long 1/8 inch thick metal to slide under the front portion and back portion to rest the inset on. No issues.
F32 Fly 1975
