Clean machine on ebay (va )
Re: Clean machine on ebay (va )
The starboard is a merc 233 (rev rotation ) , The port is a marine power 250hp . both have the marine power type water pump ( bolted to the crank ) the older merc 233 always put out more power then the newer Marine Power 250 , and honestly you can't tell the difference between the 2 looking at them since the both have the same pumps and both have aftermarket manifolds and risers .
To bid or not opps I mean to bid again . All I want is this boat you have a good home . :cry: :cry:
It when for 1500. I hope they do her right .
