Fiberglass Restoration: or "Too Much Time on My Hands"
- Commissionpoint
Great Styx tune BTW.....
So after blowing up several threads here this morning, and going to my only meeting of the week at 10am I decided I should probably try to get something productive in to the mix today. I walked over to the dock around noon to have a go at cleaning up the superstructure on the F-32. Honestly, its totally in the $hits; or it was anyways. Heres what it looked like when I started in on it: Then I got out the 800 grit wet paper and started to give it a little "What For", as we like to say around these parts. Things really started to take a little shape after a couple hours, and a lot of chalk and film, and old wax later.......
- Commissionpoint
Re: Fiberglass Restoration: or "Too Much Time on My Hands"
Then I got around to the Stbd. side. I knew there were some issues here, but I had no idea what really was going on until I started to get into it. Heres what it looked like after the 800. I know it just looks dirty in this pic, but thats a mess of poorly done glazing putty on there in order to , ostensibly, cover up some scratches.
So I walked back to the garage and broke out the big guns.
When I got the crap off, I started to see why it was put on in the first place. People, please, if finish work isn't your bag thats fine, better to live with it until you can afford a pro than it is to pretend to be one.
- Commissionpoint
So 2 sheets of 400 Wet/Dry later I had all the crap off, (and most of the original scratches too, imagine that.
) If I am going to get it right I am going to have to sand more and then get my buddy Ed over here with some gel and a vac bag. He'll hook it up good. Probably will wait till next spring though unless he happens to be starving for work.
Then I started in buffing back on the port side with some 1500 grit compound. I like using this stuff for medium cut.
I was able to get some of the port side done with a first compounding, but it became dinner time, and I had already been at it about 5 hours. I decided to knock off until tomorrow at that point.
- Commissionpoint
Here. I'll RAGE a little more for you all.
DON'T FRIGGIN' DO STUFF LIKE THIS IF YOU ARE NOT QUALIFIED!!!!
UGH!!!
IT MAKES ME WANT TO EAT BABIES!!!!!
ARRRRGGHHHHHH!!!!!!
UGH!!!
ARRRRGGHHHHHH!!!!!!
Put some teal dock lines on her no one will notice anythings else
- aaronbocknek
aaaaaahhhhhhhhhhhhhhhhhhhhh i knew i should have never mentioned the color of the lines. i will NEVER live this one down. it's a good thing you all are in my corner, otherwise...............prowlersfish wrote:Put some teal dock lines on her no one will notice anythings else
- Commissionpoint
True. I hadn't though of that! With teal lines who would be looking at anything else!prowlersfish wrote:Put some teal dock lines on her no one will notice anythings else
- Commissionpoint
True, NEVER sounds like about when you will be living the teal lines down.aaronbocknek wrote:
.............aaaaaahhhhhhhhhhhhhhhhhhhhh i knew i should have never mentioned the color of the lines. i will NEVER live this one down...........{snip}
............and no, it's neither benetton nor alexander julien (CP, i KNOW you know the color combos this guy tossed together!!!).
So.... What are you saying there Aaron????? I should somehow know something about 80's fashion???
Fashion like that should come with a free bowl of soup. Looks good on you though.
- aaronbocknek
i figured you knew something about AJ since you mentioned benetton....Commissionpoint wrote:True, NEVER sounds like about when you will be living the teal lines down.aaronbocknek wrote:
Fashion like that should come with a free bowl of soup. Looks good on you though.![]()
- Commissionpoint
I only do the whitefish&pike in jellied broth with extra red horseraddish.
Buy a governor spring. They are like 4 bux. Let me know what happens after that. I am not free until October.
- aaronbocknek
mmmmmm i remember my uncle making home made horseraddish for passover. strong enough to melt your sinus cavity. governor spring will be ordered tomorrow. it's on my list of things to do. powering down for the night. later guys.Commissionpoint wrote:I only do the whitefish&pike in jellied broth with extra red horseraddish.
Welcome to the Food channel .
- Commissionpoint
Based on your weight, I'm surprised you'd object.prowlersfish wrote:Welcome to the Food channel .
KMAJ
KMAJ
