can anyone tell me the height of a 1977 trojan F 32
dfg4240
Post by dfg4240 »
need it for a shipping quote but can't find it.
thanks
Commissionpoint
Re: can anyone tell me the height of a 1977 trojan F 32
Post by Commissionpoint »
Loaded question.
Height to the top of the bridge rail from the waterline is almost 12 feet. More with the masthead light. Less with the bridge removed. (Which is what you will have to do to move it any distance.)
Height to the top of the F/B sole with the bridge removed while on a trailer is the dimension you are looking for. I can tell you its about the same as the height from waterline with the bridge on, but I don't have exact measurements. When we moved ours it only had to go a couple miles, and half of that was through a residential area. We just left the bridge on and raised the secondaries up with a broom when we had to pass under them. That would NOT work in most places.
Hauling F-32.jpg (102.76 KiB) Viewed 4866 times
summer storm
Post by summer storm »
Factory specs F-32 sedan-
Waterline to top of flybridge 11'3"
Waterline to top of hardtop 8'0"
keel to waterline 30"
Doug
1977 F-32
1982 Chris Craft 280
1974 F-25 (Sold)
1979 F-26 (sold)
dfg4240
Post by dfg4240 »
ok thanks
I will probably take it here on the water -I don't want to take the flybridge off.
thanks again
dfg4240
dfg4240
Post by dfg4240 »
OK-Here is I just received form the broker
Dimensions
LOA: 32 ft Beam: 13 ft
Max Bridge Clearance: 12 ft 6 in
Max Draft: 2 ft 6 in
Displacement: 12000 lb
Number of Engines: 2 Primary Engines: Inboard Drive Type: Direct Drive
Engine Make: Mercruiser Engine Model: 233hp Engine Year: 1977
Propeller Type: 3 Blade
Tankage
Fuel Tanks #: 4 Fresh Water Tanks
Capacity: 30 gal
Holding Tank Capacity:
2 50 gallon fuel tanks and 2 60 gallon fuel tanks for a total of 220 gallons.
Manifold for full control of each tank.
Commissionpoint
12'4" sounds about right waterline to masthead light.
13' is the correct beam.
30' is a bit short....
12000 lbs. is a bit light....
Other than those last two things your figures look to be about right. Figure it to weigh closer to 7 or 7 1/2 tons unless you strip everything off it and empty all of the tanks.
Re: can anyone tell me the height of a 1977 Trojan F 32
12000 lbs is is the correct weight from the factory per Trojan, add for gear and fuel etc.
30' maybe the water line length But the real length it closer to 32' plus pulpit amd platform if you have these .
dfg4240
Post by dfg4240 »
Commissionpoint wrote:12'4" sounds about right waterline to masthead light.
that length was a misprint by me-it is 32'
dfg4240
thanks for catching it
