10 meter reverse rotation, engine or tranny??
I searched the forum and couldn't find an answer, sorry. I think my 1987 10 meter mid cabin has reverse rotation on the starboard engine? not tranny correct? The machine shop asked me and I wasn't sure so I told them I would get back to them.
Thanks
Thanks
Todd Pote
1987 10 Meter Mid Cabin
Double Pote-N_Sea
Double Pote-N_Sea
Re: 10 meter reverse rotation, engine or tranny??
Starboard engine is reverse rotation.
Dennis
1989 10 Meter Mid-Cabin
Only one way to be sure in case things have been changed; crank engine or check firing order.
(don't remember which one)
I was pretty sure it was the starboard engine but I figured I'd ask.
Thanks
Thanks
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
A few years back I was on 2 Trojans they had the reverse turn engines on the opposite sides , one boat was a 10 meter flybrige aft Cabin the other a 10 or 11 meter flybrige sedan .
++1prowlersfish wrote:A few years back I was on 2 Trojans they had the reverse turn engines on the opposite sides....
Big D wrote:Only one way to be sure in case things have been changed; crank engine or check firing order.
I do believe I'll have them confirm the firing order.
Thanks
Thanks
Todd Pote
Double Pote-N_Sea
Double Pote-N_Sea
Hey Todd, the starboard side is the reverse rotation motor. Had that one rebuilt last year and in the process of doing the port/standard rotation one this year. The firing order for the reverse motor is: 2-7-5-6-3-4-8-1.
Take care, Mike.
Take care, Mike.
1987 10 Meter Mid-Cabin
Twin Crusader FWC 454's
The machine shop should be able to tell by the camshaft as they are different for LH. RH. rotation
