Leaking rudder stuffing box?
Has anyone tried adding more flax to the rudder stuffing boxes while still in the water. Is it a safe thing to do?[/i]
1978 F-32 Knotty Playsure twin 350xl 270 Crusaders
EDMONDS WA
Teach a boy to fish and he will go hungry supporting his boat
http://s1123.photobucket.com/albums/l550/Larrys78/
larrys@wsconline.net
EDMONDS WA
done my shafts in the water, have the packing pre cut and tools ready, Have to ask have you tried to adjust it ?
The nut seemed to be stuck and was afraid to get to aggressive while in the water but thinking of giving it another try.
EDMONDS WA
EDMONDS WA
- boatsnbars
Make sure there is some thing on the rudder shaft to prevent it from falling out. I repacked my old (non Trojan) boat on land and when I removed everything and loosened the packing nut the rudder slid right out on to the ground. It was my first time repacking and I remember being glad I did it on land. Water pouring thru the hole would have been bad and possibly losing the rudder on the bottom would have been worse.
1988 Trojan F36, 2004 Palm Beach
You only need toremove the packing nuts nothing else . so the rudder will not fall out.
Are you losning the lock nut first ? you need to hold the big nut and lossen the lock nut . So 2 large wrenches are needed .
Not sure, It was a few years ago I need to take another look it pretty tight quarters down there due to the rear fuel tanks.
EDMONDS WA
EDMONDS WA
