Tank Saver
Tank Saver
This is a great add-on for those who have their holding tanks pumped out and find their tank collapsing under vacuum while being pumped out. It's a check/relief valve that is so easy to install. Think about the size of hose used to pump out your tank compared to the tank's vent hose size. That little vent hose can't possibly let in the same volume of air that the pumpout station is withdrawing hense the folding tank syndrome. So Sealand came out with this product and I thought I should pass it on. A hole saw is all you need to install the unit. Cut a hole, insert the collar, then insert the valve. When the valve is inserted, it expands the collar which seals it against the tank. Simple and proven. Here's a pic. Available at any Sealand parts dealer.
http://www.ardemco.com/sealand-31325524 ... ief-valve/
Thanks Big D. I haven't had any problems to date but why chance it? When I install my new holding tank I am definately installing one. One of this winters many projects.
2011 Trojan Rendevous
Solomons Get Together 2011
Ocean City 2012,2013,2015
Since you are changing tanks...Why not just put in larger vents? 2, one each end of tank and make them 1".Allen Sr wrote:Thanks Big D. I haven't had any problems to date but why chance it? When I install my new holding tank I am definately installing one. One of this winters many projects.
Why, because of odour reduction. Most holding tanks smell because not enough fresh air can get in to allow for correct bacteria growth.
Courtesy the holding tank expert, Peggy Hall...
ODOR CONTROL
It really IS possible to have a completely odor-free system!--honest!!!
You have read or heard, over and over again, that the key to odor control is the hose, that hose permeates with sewage and causes the system to stink. That’s folklore. The key to odor control is in the installation of the entire system. What very few people in the marine industry have learned is the very nature of sewage itself and how it breaks down, what creates odor and what prevents odor from forming. Once we understood proven sewage management principles and how to apply them to onboard systems, we were able to install systems that are completely odor-free and correct the ones that weren’t. Once you understand it--and it’s so simple!--you can do the same thing.
There are two ways to deal with holding tank odor: try to reduce it, mask it, and contain it after it’s formed, by using chemicals and filters—which has never proven very successful…or prevent odor from forming in the first place by applying the same principles that are used to balance and maintain sewage treatment ponds. In fact, sewage treatment ponds only stink when they’ve been unbalanced biologically by an overload of chemicals! Here’s how it works:
Sewage contains both aerobic (need oxygen to survive and thrive), and anaerobic bacteria (thrive in an airless environment); neither can function in the other’s environment. Why is that important? Because only the anaerobic bacteria in sewage produce foul-smelling gasses! Aerobic bacteria break sewage down, as does anaerobic bacteria--but aerobic bacteria do not generate odor. So as long as there is a sufficient supply of air to the tank, and an aerobic bacteria treatment is added to aid that which naturally occurs in sewage, the aerobic bacteria thrive and overpower the anaerobic bacteria, and the system remains odor free.
A bio-active (Iive aerobic bacteria) holding tank treatment such as our own "K.O." works with the aerobic bacteria in sewage, eliminating odor, completely emulsifying solids & paper, and preventing sludge from forming. Enzymes do little if anything--a brief respite from odor immediately after adding them, then odor begins to build again. Chemical products only mask odor with another odor, and they kill not only odor-causing anaerobic bacteria, but beneficial aerobic bacteria as well--not good, because the aerobic bacteria are needed in the system to break down and emulsify solids and paper. Chemicals only break them UP and dissolve them into little tiny particles that settle to the bottom of the tank, along with chemical residue, to become sludge that turns to concrete. Plus, chemicals, unlike bio-active products, are also unwelcome in landside sewage treatment facilities, and are especially unappreciated by those living and working near them!
The bacteria in sewage produce a variety of sulfur monoxides and dioxides (which are the malodorous gasses), methane--which has no odor but is flammable--and carbon dioxide, which also has no odor but creates the environment in which the aerobic bacteria cannot live, but the anaerobic bacteria thrive. Carbon dioxide does not rise or fall, it is ambient--like the atmosphere. Without a sufficient flow of fresh air through the tank to allow it to dissipate, it simply lies like a blanket on top of any pool of sewage (whether inside hose or a holding tank) and builds, suffocating the aerobic bacteria and creating the perfect environment for the anaerobic bacteria to take over. The system literally "turns septic," and the result: a stinking boat…or at least foul gasses out the vent line every time the head is flushed.
To prevent this, let’s start with the head: the discharge hose, no matter whether it goes overboard, to a Type I or II MSD, or to a holding tank, should be installed, if at all possible, with no sags or low places where sewage can stand. When a marine head is not flushed sufficiently to clear the hose of sewage and rinse the hose behind the sewage, that sewage sits in low spots in the hose or bits of it cling to the walls of the hose—getting no air, allowing the anaerobic bacteria to thrive and produce their stinking gasses. If sewage stands in a low spot which gets no air in hose which is susceptible to a high rate of water absorption, it will permeate the hose. This is what has given rise to the myth that the "wrong" hose causes odor. Therefore, as I’ve already said, flush your head thoroughly enough to clear the entire hose of sewage and rinse behind it. And when you leave your boat to go home, flush the head thoroughly one last time, this time with fresh water. Until holding tanks came along, the hose was the source of most odor, but incomplete flushing was the real cause.
In the holding tank, the key to odor control is the vent line; it must allow a free exchange of fresh air for the carbon dioxide generated by the sewage. Therefore, those bladder tanks which have no vent are all but guaranteed to stink; there’s no source of air into them at all. Boat builders, boat owners and boat yard personnel who install holding tanks have always viewed the vent line only as a source of enough air to allow the tank to be pumped out without collapsing and as an exhaust for methane (Many even believe methane--which in fact is odorless--to be the source of odor.) Some take the attitude that tanks are going to stink so the thing to do is run that vent line as far from people areas—cockpits, sun decks, etc.—as possible, or make the line as small as possible, or install a filter in it. All of the above actually create the very problem you want to solve.
Think of the holding tank as a stuffy room which needs to be aired. You know that even if there isn’t a hint of a breeze outside, just opening a window will allow the fresh air outside to exchange with stuffy air in the room. Open another window for cross-ventilation, and the air exchanges even faster. However, just opening a skylight accomplishes nothing unless there’s also a mechanical means (an "attic fan") of pulling the air up and out--and that won’t work unless another window is open to create airflow. But the only "window" into a holding tank is at the end of a "hallway"--the vent line. If that "hallway" is too narrow and goes around corners, takes a long and curved path, or rises more than 45 degrees above horizontal, no ambient air can find its way to the tank to dissipate and exchange itself with the gasses in it.
Vent the tank with as short, as straight, and as horizontal a line as is possible, with no sags, no arches, and no bends. The minimum I.D of the hose (which is the "standard" size in use today, but for no reason other than being "standard" in fresh water and fuel tainks) is 5/8"; we recommend that it be at least 3/4". Ideally, it should be no more than 3’ long. If it has to be substantially longer, or if running the vent line uphill more than 45 degrees off horizontal can’t be avoided, or if it’s impossible to run a vent line that does not go around a corner, increase the size of the vent line to 1" or even larger. If, for instance on a sailboat, the line must go up to the deck, install a second vent line in order to create cross ventilation, or install some mechanical means of forcing air through the tank. We prefer to put holding tanks in the bow of sailboats--under the v-berth--because the hull just behind the point of the bow is the only place on the hull except the transom that will never be under water even when the boat is at maximum heel; it’s the perfect place to install vent-line through-hulls, because the though-hull is always into the wind, forcing air into the vent line, when the boat is underway or on an anchor or mooring. The vent through-hull should not be the same type as a fuel vent through-hull (a cap with a slit in it), but should be a should be a straight open type through-hull.
On sailboats especially it’s advisable to vent off the top of the tank and not the side, because heeling can cause the contents of a half-full or more tank to run into the vent line. Because a filter blocks the flow of air into the tank, install a vent line filter only as a last resort; the filter does trap the gasses which try to escape through the vent line, but a filter will not stop gasses from forming, and therefore from going back up the inlet hose into the boat or up the outlet hose—and eventually permeating even the best hose.
Check the vent line regularly for blockages; little insects love to build nests in them. And remember--the vent line is not an "overflow!" So try never to overfill the tank; bits of sewage can clog the vent line. Enough air can pass through it to allow the tank to be pumped and gasses to escape, but that doesn’t mean the line is completely clear of any blockage.
Finally, the system, including the tank, should be at least nominally rinsed, through the head or back down the deck fill—with fresh or salt water—after each pump-out, and occasionally with fresh water. (If your marina doesn’t have a dock water hose for this purpose, please ask them to install one. It should be separate from the potable water hose, and the two hoses should never be interchanged.)
We promise: if you install and maintain your system according to what I’ve said here, you will have NO odor! In fact, you can be standing next to the vent line through-hull when the head is flushed --and you won’t even notice it!
I completely agree. If doable, enlarging the venting volume is the best way to go not just for smells but to prevent tank collapse. The valve is just an option to prevent tank collapse.ready123 wrote:...Why not just put in larger vents? 2, one each end of tank and make them 1"....Most holding tanks smell because not enough fresh air can get in...
I agree the way to minimize hose permeation is to use enough water to clear the entire hose of the nasty stuff in a manual flush system. The amount of water you'd need to flush the lines every time you flushed waste though would fill your tank real quick. There are other ways to control odor, it is a real science, and the biggest part of odour control begins with the installation of the entire system. Something as simple as using fresh water rather than raw water makes a difference (surprised she didn't mention that). I for one am a big fan of the Vacuflush system. If installed properly, you should have no smells at all. Once it flushes, there is nothing in the vaccum side of the system from the pump all the way to the toilet thus no smelly lines (if installed properly), they use very little water to flush, and designed to macerate before the stuff leaves the bowl. They also have the best hose in the market which is said to be impermeable but if you really want to get away from hose permeation, use solid ABS pipe in long runs with elbows or anywhere in the system that is practical and has standing fluid in the hose at all times. Remember that the more flexible the hose is, the more permiable it will be. Systems with "Y" valves are a good example of having sections of hose with long standing nasty stuff in it. A Vacuflush install can be pretty pricy but what price do you put on having a happy wife?
- Commissionpoint
Some kind soul installed a nice Vaccuflush system in my F-32 long before I got it. John & Nancy did some upkeep on it while they owned it, and I should probably replace the bowl seal this spring (Nancy gave me the parts already, it has a slow leak) but its a great system and it never smells. I'll probably replace the charcoal this spring too, but thats just being proactive.
RWS told me to try baby oil to fix the leak and it did the job for me.Commissionpoint wrote:Some kind soul installed a nice Vaccuflush system in my F-32 long before I got it. John & Nancy did some upkeep on it while they owned it, and I should probably replace the bowl seal this spring (Nancy gave me the parts already, it has a slow leak) but its a great system and it never smells. I'll probably replace the charcoal this spring too, but thats just being proactive.
John
"PELICAN"
1983 10 Meter Express
"PELICAN"
Besides an aged seal, the most common reason for a bowl seal leak is solids stuck to the underside of the seal that makes contact with the ball. Shut the water off, push the pedal to roll the ball and with a wet rag, rub the underside of the seal around the seal's rim. Of course if the seal hasn't been replaced in a while, it's a good idea to do so. It's not difficult or expensive, and minimizes pump run times and water usage.Commissionpoint wrote:....I should probably replace the bowl seal...it has a slow leak....
Someone may be able to answer that for you. I don't use the stuff regularly so I can't comment. It's one thing to read about such products and their benefits but every system is different, and the user's habbits have a huge impact on tank conditions as well. What may work for one user may not for another. The worse thing I see folks do is have stuff in thier tank and while at the marina use the marina washrooms in hopes of minimizing pumpout frequencies/$$$. All that does is make what's in the tank really brew up a good smell. Nothing stays in my tank very long so haven't felt the need to use such products on a regular basis unless I am away from any port for an extended period.Oxblood wrote:Would added one of the bilological treatments assist as well?
The most important thing I can tell you about any toilet system is to never, never, never put Pinesol in it. The previous owners of our F32 were very proud that they used such a wonderful product. Well, it corrodes rubber and metal, and the boat stank, and one of the first projects was replacing every component except the bowl and the pump (which we sent out to be rebuilt). So...vacuum tank, switch, hoses, holding tank. Ugh. Not fun. We re-engineered it with extensive help from Peggie Hall, who coincidentally used to own an F32. She and I still keep in touch occasionally.
A well-vented system is sometimes tricky to install, but it shouldn't need a vent filter. Michael, unless you added one, there's no charcoal filter on your boat.
Though this may get you by in a pinch, I wouldn't use any oily product in the system. If there is a leak, it typically indicates a part that needs cleaning or replacement. Oil is great for lubricating but it also binds solids together under certain conditions. This is deffinately not desirable in components like the pump. Oil will help paper bind to the pump's bellows which is designed so that paper doesn't clog it up. There are natural oils in our waste that the system must deal with so any additional oil we add compounds problems associated with oils, and it's difficult to get rid of once it coats surfaces and components.jhalb wrote:....try baby oil to fix the leak and it did the job for me.
Here's a good survey; how many people are using regular household toilet paper in their Vacuflush systems? The answer should be nobody unless you WANT to service them more often!
You're absolutely right Nancy. The point here is that typically most folks use multi-ply household paper they bring from home which is a no no. The problem with household single ply is that most folks double up on it's use or it doesn't do much if you know what I meanNancy wrote:....The test is to put a single sheet in a bowl of water and swirl briefly. If it falls apart immediately, it's fine.
- Commissionpoint
No wonder that thing is so "bombproof". You guys really did a good job.Nancy wrote:........and the boat stank, and one of the first projects was replacing every component except the bowl and the pump (which we sent out to be rebuilt). So...vacuum tank, switch, hoses, holding tank. Ugh. Not fun. We re-engineered it with extensive help from Peggie Hall, who coincidentally used to own an F32. She and I still keep in touch occasionally.
I had just assumed it had a charcoal filter. You just saved me a bit of time looking for one.
So the Pinesol people and the Cetol people are one in the same?
