Velvet drive info
~DarkNemesis~
Velvet drive info
Is there a way to tell the difference between a 70c and a 71c? I have a manual that contains both from BorgWarner but even after reading, I cant seem to find a way to tell them apart. I must be missing something and we need to know so this guy can order the correct kit. The velvet drive I bought last spring has no tag or visible markings. The manual I have covers the 70c and 71c plus service info for the early asi-70b, asi-71b, asi-70 and asi-71. My question is, are there ways to visually tell them apart. Lack of parts? different parts? Are they exactly the same? I know they are very close, Im not going to chance it for 160$ Maybe someone knows a company local in hampton roads that can look at it for us?
~DarkNemesis~
~DarkNemesis~
I am. Trying to work a deal with a guy. Told him i would help best i could. . Its alot of boat on the dry to get rid of. Thanks for your honesty, im welding on the truck tonight. Ill ppst a picture in the morning. Its all sand blasted and just the tranny no mounts. Im may get stuck with this boat. Hes asking really dumb stuff like i did. I dont have the heart to cut this boat apart. I know what i said
The ID tag is located on the top of the left-hand transmission mount (per the owner's manual).~DarkNemesis~ wrote:I had a feeling the manual was missing a few pages, its hand made, photo copied in a binder. No pictures of full assembly.
Here are the specs, classifications and owners manuals for the 71c & 72c:
Velvet Drive 71c-72c Series (Straight Drive):
http://RNR-MARINE.com/TROJAN/Borg-Warne ... _Specs.pdf
http://RNR-MARINE.com/TROJAN/Borg-Warne ... atings.pdf
http://RNR-MARINE.com/TROJAN/Borg-Warne ... Manual.pdf
The 72c ( 10-18-xxx-xx ) was built heavier (and weighed 8 or 14 lbs more) than the 71c ( 10-17-xxx-xx & 10-04-xxx-xx ) and could handle more HP. For example, the maximum ratings were on the In-Line 1:1 models:
Model 71C In-Line 1:1 :
- . gas HP 310@4200RPM
. Diesel HP 182@3200RPM
- . Gas HP 475@4200RPM
. Diesel HP 274@3200RPM
The two reasons for still using an older style reduction housing are: 1) You can bolt a bracket to the back end, which can be used with a shift control cable, and 2) To be able to use a 4-inch diameter output coupler instead of a 5-inch (both transmissions shown to the right have 5-inch couplers, but only the older style has the option of using a 4-inch coupler).
Good luck ...
Re: Velvet drive info
~DarkNemesis~ wrote:Is there a way to tell the difference between a 70c and a 71c?
There is no tag on it . And its a 1 to 1 gear , I should be able to ID it the are differences in the case
~DarkNemesis~
No need to wait for Paul to drive over. If there is no tag, and its a direct drive (1:1 ratio) unit you can measure the housing to tell the difference between a 71C and a 72C unit (and look at the shape, which is harder to quantify here).
The length ("C" in the picture below) is the easiest check:
- > The 71C "C" length is 10-1/2 inches from the point it mounts on the bellhousing to the end of the output flange.
> The 72C "C" length is 11-7/16 inches from the point it mounts on the bellhousing to the output flange.
70C - 71C
Ross waiting on a PHOTO not driving over . And he is tryin to tell if its a 70C or 71C . ( not 72 )
And its a 1 to 1 not a reduction gear unit
If my scaner worked I would post the drawings of the 70C 1:1
prowlersfish wrote:This could solve the proplem ( I know you don't like diesels but that could be a deal or a po-
http://norfolk.craigslist.org/boa/3323165986.html
trojanmanXS
prowlersfish wrote:Ross waiting on a PHOTO not driving over . And he is tryin to tell if its a 70C or 71C . ( not 72 )
70C & 71C are the same size (same 10-1/2" C dim. mentioned above) ...prowlersfish wrote: And its a 1 to 1 gear , I should be able to ID it the are differences in the case
so you won't be able to tell that from a photo.
FYI - the 70C is only rated to 180HP. Not sure you can externally ID it versus a 71C without the tag.
Here is the 70/71 service manual ... differences are noted ...
http://rnr-marine.com/trojan/Borg-Warne ... -&-71C.pdf
The drawings I have show some slight differences but it could be the differences in the year .I will look at them again when I get a chance .But its really is no big deal as they take the same kit anyway .
http://www.ebay.com/itm/VELVET-DRIVE-70 ... 3cbaae5ffc
Recc you get a kit with the bronze clutches
