Even before I closed on my boat, Sir Aaron of Baltimore recommended his mechanic to do some of the items flagged in the survey. Aaron's boat was still in the yard when it was time for mine to be hauled, so I asked to be blocked next to him. It is funny to watch people do the proverbial double-take.
Here is a hint, okay, not a small one, about the topic of an upcoming post, and may be the reason that I'm not performing the work in the water.
This pic is of the underwater exhaust with the outer clamshell removed.
Note the bronze tube welded to the plate.
The tube extends up into the boat to right about the LWL. This is the view with the bellows removed. Attention tricab owners, the bellows are not even fabric-reinforced -- just formed rubber. A piece of reinforced exhaust hose acts as a washer between the bronze tube and the bellows. My vintage 1985 bellows look and feel fine, and are not terribly stiff or obviously deteriorated. Nevertheless, my 2012-vintage 4-ply reinforced silicone bellows are on order.
The careful eye will note the black ooze eminating from under the low side of the thru-hull backing plate. The survey revealed a leak between the bottom of said plate and the inside of the hull. That plywood backing plate is being replaced with waterjet-cut structural fiberglass sheet. Stay tuned.....
