Continual horn blowing
New Member also new 2 year Trojan owner
1985 10 meter international convertible gas 454s
Started having problems with the port engine. Cruising for 3/4 of an hour at 2,700 rpms and lose power. Changed to electronic ignition, new fuel pump new filters, compression test. Mechanic scratching head? I decided to change coil and resistor. After the installation I was going to test run however prior to this and seeing as I was in the engine compartment decided to check battery fluid levels. Pretty good but added some liquid to 1 battery. Checked the bolts and tightened one but after I did the horn started sounding (very loud) Disconnected starboard battery leads and horn stopped however reconnecting starts horn again. Can't get it to stop, assuming it is an alarm of some kind don't want to move until I know what is causing this. Any ideas???????
Thanks for the info
- Commissionpoint
Good topic name for around here.
Check to see if your horn switch is buggered. Also put a continuity meter on the wiring to it and see if it isn't just a simple short.
summer storm
That was my first thoughtprowlersfish wrote: also is the key on or off ?
The horn will sound if the ignition key is on and the motor is not running.
http://www.cbyc.ca/
http://www.cbyc.ca/
Welcome aboard. Wow, we're starting to get a lot of folks from Ontario, I like it. I'm thinking this sounds like engine alarm; if ignition switch is off, check the ignition switch itself, electrically, it may be shorted in the closed/run position. This would power up the ignition circuit and alarm would sound due to no oil pressure. Disconnect the ignition switch and hook up the battery again. Worth looking at.
If it is the boat horn, look for a shorted switch or relay, or you may have a high water alarm float that is stuck in the "on" position while you were messing around in the engine compartment.
