I'm getting ready to do my annual fluid changes. Normally I just change engine oil but want to include the transmissions this year. I have hurth direct drives. I'm assuming I can just pump out the fluid through the dip stick hole and refill with dextron?
Is this assumption correct?
Any idea of capacity?
Do I check level warm or cold?
Any tips are greatly appreciated!
Thanks in advance..........John
Trans fluid change
Trans fluid change
1998 Kawasaki ZXi 1100
They appear to Have dextron in them......red color on dipstick.....if theres a drain there's no way to get under it. I'll pump it out and refill using dip stick mark, idle and shift for awhile and recheck........sound like a plan?". thanks.....John
