Short summer rain ...
EM63
Post by EM63 »
Thanks Jeff - do you still have some pic's from this area :lol: :wink:
Greetings - Heiner
jefflaw35
Post by jefflaw35 »
i can go take a couple pictures Heiner, but my deck is missing now. maybe I can show you a picture then explain what I remember. give me 20 minutes
EM63
Post by EM63 »
This 'Jeff' - as fast as ever :D :D
Greetings - Heiner
jefflaw35
Post by jefflaw35 »
I may be wrong Heiner. Mine sit above the deck, and drain through the transom, caused my transom deck support to rot.
EM63
Post by EM63 »
Thanks for your quick response - Jeff :D
Our vessel has these 3 drains too:
Now I have to find out, where they come from. In fact - the middle one is
just to drain the hatch - thats for sure.
Greetings (and thanks) - Heiner
jefflaw35
Post by jefflaw35 »
The lower middle yes, but the upper should be for the deck. I dont understand why they didnt make the holes bigger. They clog up to easy.
pwollsch
Post by pwollsch »
My 1974 F36 has scuppers but they drain to the cockpit bilge!
Really a bad design. Need to change to thru-hull....this winter.
1072 14 ft Meijers - Sears outboard
1990 17 ft Sea Nymph - 70 Johnson
1992 17 Tracker Deep-V - 40 Yamaha (still own)
1987 266 Cruisers Inc - 460 King Cobra
1974 F36 Trojan - Twin Crysler M400
jefflaw35
Post by jefflaw35 »
after looking again and listening to you guys, I think was designed to do the same, I dont see why though. Im going to run larger piping thro the transom to my deck so this never happens again. I agree, poor design and why such little holes?
pwollsch wrote:My 1974 F36 has scuppers but they drain to the cockpit bilge!
I would check again the when overboard when new .
EM63
Post by EM63 »
jefflaw35 wrote:after looking again and listening to you guys, I think was designed to do the same, I dont see why though. Im going to run larger piping thro the transom to my deck so this never happens again. I agree, poor design and why such little holes?
Roger that ! We will install larger (and working) scuppers as soon as possible :o
Greetings - Heiner
aaronbocknek
Post by aaronbocknek »
EM63 wrote:Thanks for your quick response - Jeff :D
so i was correct, right? not unlike the original tri cabin design until the flush deck version was introduced.
aaron in baltimore
aaronbocknek@gmail.com
aweimer
Post by aweimer »
The aft wall should stop about 1" above the deck. There should be a tray that is about 1/2" lower that runs along the aft wall where those brass scupper holes are. My try-cabin has this and it works perfectly.
See in this old picture of my deck, only one i could find with the aft image.
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
aaronbocknek
aweimer wrote:The aft wall should stop about 1" above the deck. There should be a tray that is about 1/2" lower that runs along the aft wall where those brass scupper holes are. My try-cabin has this and it works perfectly.
+++1 yep. same as the earlier versions of the f-32 and f36. this was used until the fiberglass cockpit liners were added in later model years.
tri cabin aaron
EM63
Post by EM63 »
"KNOW HOW" means to have friends like you all, they have knowledges about Trojan's :wink:
And yes, you were right. Today I moved that panel out - and 'here we are' scuppers said :?
Clogged with old leaves and maple seeds:
The middle one is also present:
Will make that hole a little bit wider:
I flooded the deck again - and all the water was flushing out as expected.
Will work at the panel too, to clean the scuppers more easy.
Greetings and thank's - Heiner :wink:
EM63
Post by EM63 »
Made some work at the teak today (using citric acid and salt):
Greetings - Heiner
