Fresh wate tank
kenearly
Fresh wate tank
Post by kenearly »
89 Trojan 12 meter International
Express. Fresh water holding tank has a crack and leaks in the lower area. Any suggestions on a fix or replacement. Having trouble getting to the area. :cry:
Ken
I have a 89 Trojan 12 Meter International
You can always put a new tank somewhere else , if you can find a good spot .
could be worse...
could be the waste tank !
but seriously, is yours built into the hull?
Are you certain the leak is from the tank?
Any space for an additional/replacement tank?
How many gallons?
