fuel tanks
glen Masters
fuel tanks
Hi all, new owner of a 1977 32 flybridge express. I need some info. The boat is being shiped in a week or two. I need the dimensions of the rear gas tanks. the boat has 4 tanks Im talking about the 2 that are mounted across the back. thanks
Glen Masters
- DAVIDLOFLAND
The original round tanks in my F-32 were about 60 gallons each. I had new ones (rectangular) built that are about 90 gallons each. I measured the available space, then left some room on top of eact tank to be able to access connections, sending units, etc.
Yanmar 6BY3-260's
Yanmar 6BY3-260's
glen Masters
Out of town, or I'd measure mine for you.
Not sure I'd buy tanks without measuring your own boat, as there could be modifications or additions in the way that affect the layout/placement. You may even want to drop from 4 to 2 tanks, unless you're planning on long range cruising. Storing 4 tanks full of ethanol tainted fuel will only make more fuel go bad (2-3 months).
glen Masters
On my '85 F32, the front are 50 gallon rectangle and the rears are 60 gallon round.prowlersfish wrote:rectangle ? I was thinking the stern tanks were round . The may have been changed .
what shape are they F32 owners ?
A couple of threads...
http://www.trojanboatsforum.net/wforum/viewt ... fuel+tanks
Here you go, I put two new Moeller tanks in my boat last year and love them. 58 gallons each, 1976 Trojan F32.
http://www.moellermarine.com/aftermarke ... ent_tanks/
