Hull all shiny and like NEW !
Torcan
Post by Torcan »
Well, after last year of trying just about every polish out there, mucho $$ and much aching muscles, I could NOT get the Hull to shine like glass. Some of the repairs that were done to the Hull, would just not come nice.
So... this year, after researching, and trying out the product on an oxidized piece of Fiberglass at the boat show, I was impressed and couldn't wait to give it a try. And yes, it is Poli-Glow.
First I cleaned it up with the cleaner they provide, then started wiping the wax on, easy as running a wet cloth. Product goes on wet, and dries very fast. The time it took me to get around the boat, the 1st coat was dry. I put 7 coats on, took me all of 2 hours, with the drying time, to wash, just mild soap and water. And, I still have half a bottle left for next year if necessary.
Rooferdave can attest to the results, as we are both members of the same club and he saw the before, and the results that I have now.
I also added the Red stripe between the Anti-fouling and the newly replaced Gold stripe.
here are the results, as promised....
http://www.cbyc.ca/
Looks great
k9th
Post by k9th »
Good looking job.
g36
Post by g36 »
I have been using poliglow since I have had my boat and ihave been very pleased
I think you will too. You'll also notice getting dirt and bird droppings will hose off and leave no marks.
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
jefflaw35
Post by jefflaw35 »
Looks awesome to me!!!!
TADTOOMUCH
Poliglow
Post by TADTOOMUCH »
Looks real nice!
I have heard from a few people that you should not use any harsh cleaners on it. Just use soap and water. The couple who have a boat like ours used it on their boat but when they used some grey streak remover, it took the shine off from their boat.
Just take care of it and it should look nice for a long time. Looks great!
Boat Name: A TAD TOO MUCH
JGedridge
Post by JGedridge »
.....Needs a couple more coats........
LOL! Looks GREAT!
Joe
Vitaliy
Post by Vitaliy »
wow that does look nice, imana have to try that on my boat, it could deffinately use some shine
Torcan
Post by Torcan »
Vitaliy wrote:wow that does look nice, imana have to try that on my boat, it could deffinately use some shine
Just make sure you follow the directions, and if you are going to do topside, make sure it gets done first, otherwise the cleaner will run down and remove the wax job on the hull, and you'll have to redo it again.
1st coat is a bit streaky, but as you add a few coats, it comes out all flat and shiny.
It looks great, I am happy with it. And my 32 year old boat was impossible to bring back to a shine with anything else. I tried them all. Believe me, had the aches to prove it.
Karate Kid, "Wax on, Wax off" sucked.
http://www.cbyc.ca/
Definitely looks good! I think mine looks pretty good too, but won't really be able to tell until I get it out of the shed to launch on Monday. Shed lighting sucks, and 1000W work light is just too strong to really see things right.
But... I think it should look pretty good based on this shot..
Last edited by captainmaniac on Sun Sep 19, 2021 12:03 am, edited 1 time in total.
Torcan
Post by Torcan »
Beautiful Captainmaniac
Is that PoliGlow as well?
http://www.cbyc.ca/
Torcan wrote:Beautiful Captainmaniac
Wax On, Wax Off!!!
Meguiar's Boat/RV Polish (#45) first, then Flagship Premium Marine Wax. Polishing takes about 2.5-3 hours per side, waxing about 1.5-2 hours per side, and about an hour for each on the transom. No power buffer, because I am scared I could burn through the 33 year old gel or end up with swirls I can't get rid of.
I still have to do the superstructure - launching early this year to save someone a few hundred$$$ so just didn't get to it yet - but I use the same products for toe rail, flybridge fairing, salon sides, and around the cockpit (all the glossy glass topsides). Non-slip gets done with a different product from Aurora that gets sticky when wet.
jefflaw35
Post by jefflaw35 »
captainmaniac wrote:Definitely looks good! I think mine looks pretty good too, but won't really be able to tell until I get it out of the shed to launch on Monday. Shed lighting sucks, and 1000W work light is just too strong to really see things right.
show off!!! :shock: Beutiful is the only words! that is perfection at its best!!!
aweimer
Post by aweimer »
The $70 kit enough to do a 28' boat top and sides 4 coats?
Aaron
____________________________
1975 36' Tri Cabin
"Keep it up!"
E-Mail : aweimer@comcast.net
Lake Erie, OH
Torcan
Post by Torcan »
aweimer wrote:The $70 kit enough to do a 28' boat top and sides 4 coats?
I put 7 coats on, F25 and still have a little less than 3/4 of the bottle left.
But I didn't do the topside, it was just cleanned up, the make-up of my topside doesn't polish, except for where the Trojan decals are.
http://www.cbyc.ca/
