Thou shall NOT build a boat with flathead screws!
1967 seavoyager
Yeah Really ! I have a few thousand more than you.
seavoyager36@hotmail.com
"Restless"
"Restless"
+1 to that.1967 seavoyager wrote:Yeah Really ! I have a few thousand more than you.
Jeff, I'll let you know if I ever have to refasten my hull, then you can go and buy shares too
- aaronbocknek
just be careful when you are extracting them. the heads are soft and they will strip in a heartbeat.jefflaw35 wrote:Lol this is unreal!!! And they drove the deep to!!!!!grrrrrrr
aaron the hebrew
- aaronbocknek
jefflaw35
Aleast they are soft and fairly easy to drill the head. Stainless would be a bitXXX. My boat has phillips heads you get one shot with the screw gun, if slips, you are screwed, pun intneded.
, then drill baby drill.
Last edited by larryeddington on Sat Feb 25, 2012 9:26 pm, edited 1 time in total.
Also beware the Phillips head brass screws that are not in fact Phillips and require a specialized driver
The name escapes me for a moment but it will come back to me,
Google gives me the answer....
And then, there is a particularly invidious little SOB called a Reed and Prince® head. It looks just like a Phillips head... but it's not. The angles are different—different enough that you can ruin the screw head if you use a Phillips screwdriver on a Reed and Prince screw, or vice versa.
and better....
The Frearson screw drive, also known as the Reed and Prince screw drive, is similar to a Phillips but the Frearson has a more pointed 75° V shape. One advantage over the Phillips drive is that one driver or bit fits all screw sizes. It is often found in marine hardware and requires a Frearson screwdriver or bit to work properly. The tool recess is a perfect, sharp cross, allowing for higher applied torque, unlike the rounded, tapered Phillips head, which was designed to cam out at high torque. It was developed by an English inventor named Frearson in the 19th century and produced from the late 1930s to the mid-1970s by the Reed & Prince Manufacturing Company now of Leominster, Massachusetts.
and better....
and then lets not for get the knuckle heads that S/S on risers or common carbon steel screws . I'm still replacing as I find them..
jefflaw35
