What size Bilge Pumps? 10M Express
Gents,
I need to start planning out what bilge pumps to get for my 10m Express. I've searched the site but haven't found anything specific for the 10m Express and particularly about pump size.
I will have 3 pumps positioned in the stock locations. One in the cabin, one in the engine room, and one in the transom. I also have crash valves on the engine seacocks as an fyi.
So, aside from the largest possible, what are good pump flow sizes for the 3 pumps? Also, should the largest pump be in the cabin since that's the lowest pump of the 3?
Thanks for any insight.
Just get bigger buckets
http://www.cbyc.ca/
http://www.cbyc.ca/
mine had 3 1500 gph pumps when I got her.
added a 3500 emergency pump to the engine room, mounted the pump & switch higher than the factory unit.
Wired that one into the genny circuit - it's totally independent of the others.
Re-attached the emergency horn system back into three new bilge pump switches.
While the fuel tank was out we cut out a section of the aft liner to get that pump lower so it could get more of that water out of the boat.
Having that "emergency" pump on a completely seperate battery system was important to me.
When I got the boat there was a battery strap to connect the genny battery to the port battery so it coule be charged in tandem from the alternator.
I disconnected that leg and installed a battery switch to allow for isolation of that genny battery.
In the event everything goes down, there's always that emergency 3500 pump attached to it's isolated power system.
That factory horn alarm system is a very nice feature.
hmmm a high water alarm.... not bad, might have to consider that one, when i purchased my boat the previous owner had this strip sensor attached right below the ac that was supposed to be the high water alarm however after pouring a bucket of water on it nothing happened so we tore it out (probably bad) so i might have to find one of those and install it
+1 RWS, having all your pumps wired to the same power source is not a good idea. Spreading them to different banks reduces the chances of them all failing at once due to power source or circuit failure. You can never have too many redundant safety systems IMO. Wiring the horn to the high water pump circuit is a must in my books. The more attention you can bring to a sinking ship, the better the chances that someone can take action to prevent disaster.
The large pumps are great for volume. If adding one to existing wiring however, you will deminish the pump's pumping capacity and sacrifice safety if the wiring isn't sufficient to accommodate the larger pump's electrical load. Aside from the safety issues, you can conceivably reduce the rated volume of a 2500 GPM pump to 2000 or much less depending on the wire used. Kind of defeats the purpose of trying to keep her afloat but setting her ablaze in the process. Don't cheap out on the electrical hardware!
Vitaliy, there are several devices and rigs you can make up to trigger a pump but a regular float switch is probably your best/easiest set up. There is more exotic hardware available but the floats work just fine if maintained right. The high water one won't get any action unless there's an emergency and as such should be checked for proper operation at the start of every season at least. All floats should be checked.
My 10 meter came with three factory bilge pumps & float switches.
Additionally the factory high water alarm system wired into the horn relay has it's own three additional float switches with the appropriate markings.
I added a manual override switch in the cabin to kill the horn in the event it should become necessary.
It appears that they split the system..
The two main breakers for the bilge pumps are wired to port / starboard.
Nice, well thought out system.
then you could always plum your raw water pumps in as crash pumps\, bucket list...RWS did hit on a good ideal to use the gen battery for the back up pump...
And float switches should have a cage over them to prevent anything that is in the bilge from interfering with the switch's mechanical operation. If something floats or rolls under the switch it can jam it on (draining your battery or burning out the pump) or off (making it ineffective).Big D wrote:Vitaliy, there are several devices and rigs you can make up to trigger a pump but a regular float switch is probably your best/easiest set up.
Had a friend with a SeaRay 36 Aft Cabin - on one trip while out and running his wife went down into the aft cabin for something and found 2" of water above the floor. Getting water in the bilge was 'normal' (accumulation from rain runoff etc) but was normally evacuated by his float switch activated aft pump. But the pump never kicked in because a coil of wire that was bouncing around in the bilge had landed on top of the float switch and had it pinned down.
