1975 f 26 trojan water tank
32pacemaker
Post by 32pacemaker »
what size water tanks are fitting under the decks on the 1975 f 26 boats and is any one using hot water tanks
foofer b
Post by foofer b »
I think my fw is a 30 gal and my hw tank is a 6 gal.
MY CURRENT FLEET
2003 KEY WEST 2020 WA
1978 14' ASHCRAFT SKIFF
Not sure about your year, but my manual for '79 says both the 25' and 26' had 20 gallon tanks from the factory.
foofer b
Post by foofer b »
My po put a new tank in along with new water pump and lines.
MY CURRENT FLEET
mitch
Post by mitch »
Next winter, I'll use my water tanks !
Post by Paul »
My F-26 has a 20 gal aluminum fresh water tank that was factory installed and a 6 gal Seaward hot water tank that I installed myself.
randyp
Post by randyp »
I replaced the metal tank installed by the dealer (not the factory) in 1977 with a poly 20 gal tank, and two years ago installed an Atwood 11 gallon hw tank replacing the 11 gallon original tank that WAS installed at the factory. Weird way things were put together on the boat.
Randy P
1977 F-26 HT
"Blue Heron"
