I would'nt be unhappy to get some pictures of this, cause I'm not be very convinced about thisgettaway wrote:Hi I was asking because I found two original mercruiser carburetor throttle brackets but it looks like you did a nice job fabricating them
Wanted: Detailed pictures from carburator connection Merc233
Looks good. In pictures one and three, I like the shelving for spare parts, etc. Someone made use of some good space.
In picture # 2, I see you have an electrical outlet in the engine room. (right next to your fuel lines too) Pretty sure it's not to ABYC standards for a gasoline boat.
Not sure if that's your boat or Ricks...
Just be careful...
Just be careful...
- Commissionpoint
Heiner, I see you have two different ignition coil setups on your engines. The port one looks to be the old style GM coil, and the Starboard one looks to be an aftermarket replacement one. Are you going to be upgrading the ignition system as part of your work, or are you leaving it this way. I only ask because I am thinking of upgrading to breakerless ignition and I am curious about the different options available.
- Commissionpoint
I guess you are right Paul. Musta had a brainfart.prowlersfish wrote:Hard to see both coils but they look to be stock Mercruiser set up.
... excuse me - please
As Jamie noticed correct - theese pictures are from Capt. Rick Budda's vessel
Our Beauty is already winterised and theese missing parts are ordered:
Still glad to have friends like you
Greetings - Heiner
Just pictures he placed in his thread what we were looking for.Thanks to Capt. Rick Budda we've got the last needed pictures to finish our work
Greetings - Heiner
