1974 f32 cracked windows
the f32 I'm lookin at has a few cracked windows how to and what replace them with, plexi or safty glass???
have you tried the search feature on this forum?. there are several threads related to this topic. there will be pros and cons of using glass or lexan/polycarb. this is one of the the things our f boats all seem to have in common is the window cracking
1997 CARVER 405
"the BLACK PEARL"
past fleet
1978 F32 SEDAN CHRYSLER 318's
current fleet
1997 seadoo gts
1997 yamaha wave venture
1985 sunbird 18 ft runabout
1968 coronado sailboat 25 ft
sunfish
14' hobie cat
canoe
8ft portabote
"the BLACK PEARL"
past fleet
current fleet
1997 seadoo gts
sunfish
14' hobie cat
canoe
8ft portabote
My vote is glass. I replaced mine about 5 years ago or more...and have no issues yet.
Why have a salon if you're gonna use plexi? Just sayin'.
- Struts and Rudders
We are planning on all new glass...though we are considering rebuilding the framing with structural foam and fiberglass to replace the aluminum frames.
As to the removal of the flybridge...we went down that road and decided to go back with the bridge due inpart to docking and navigation in tight spaces...the view and access to speak to dockside assisitance was our largest concern overall.
SRD
F36
SRD
F36
- Commissionpoint
Both. Laminated is a must for safety concerns, and tempered is much stronger than non tempered glass. The combination of both is definately a bit more spendy, but I would hope you are only planning on doing this once, so it would be well worth the added expense.
I too am going to be replacing the front glass on the F-32 salon in the 2012 season. The delaminating on the corner of the center pane gives me fits. My biggest concern isn't the cost of the glass or the installation, but getting the damn blue tint done right at the top of the panes. Its a dipped tint and not a film. I suppose its not a must have, but I am a bit of a stickler for details.
this so true the only time I look thru mine is when I'm cleaning them, then that cover goes right back on..Nancy wrote:CP,
You saw the boat with a naked front window. Don't forget there's a windshield cover. If you use it, you won't even notice the tint.You might decide that it's not critical after all.
Nancy
- Commissionpoint
Thats true Nancy. The cover will most likely be on the majority of the time. If its something thats easy I will probably have it done. Otherwise I will abandon the tint.Nancy wrote:CP,
Nancy
I have to yet to find one and I have looked at a lot however I have
heard of the proplem and thats why I have looked I have no doubt
that you have run in to it fresh vs salt water ? could be also I
have looked at them a lot in the last 5-6 years. if wood is going to
rot or is badly sealed it may have happen early on and the bad ones
are long gone or have been fixed one last thing we are all here for
the same resone so there is no need to call me Sir whether we agree
or not . with that said he sould take a good look at the stringers
just in case . also look for soft spots on the decks and briges
this goes for all boats not just Trojans . and get a good survey
